Got some R34 gt-t stock parts for sale....All are in reasonable condition....taken off the car at around 50000 k's...Cant be bothered to research prices so all are open to offers.
I am located in the hills district sydney and parts only availiable for pick up.
Contact: Steve - 0422633232
Parts:
Stock Suspension
Complete Stock exhaust (front pipe through to muffler tip)
Standard Side mount intercooler (with are vent thing, mounting bracket and a bit of pipe)
As i said i dont know what these parts are worth so just make an offer if you are interested...i am pretty easy going.
cheers Steve
https://www.sau.com.au/forums/topic/268510-stock-34-gt-t-parts-sale/
$20 for the exhaust if your keen, you prob think thats nothing but not many people want them.. Let me know if your keen.
20 is a lil low mate...i seen them selll for 200 b4 so maybe a lil closer to the 100 mark would be nice
SHOTGUN SMIC plzzzz need it sent to melbourne though :D im willing to pay for expenses
man can u please give me a call tomoz during the day to sort stuff out...that way i can post it in the arvo...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
