Hey Guys,
After hearing all these news about stolen cars on the road, l don't know why everyone hasn't invested in one of these GPS tracking devices yet.
I've had one of these installed in my vehicle and they were fantastic so lm offering a group buy for this tracker.
This device was developed here in Australia at the UNSW by some of the countries leading researchers. These have been tested to be up to 5m accurate in the long run.
These Normally retail for $450 for the set, however if we order 10+, we can get them for $400. So if you're interested, please give me a PM and ill put you down for one!
This is a small price to pay to protect your investment and once this goes mainstream, prepare to pay big bucks for it!
The specs are:-
- The TLT-1B GPS, GSM Tracker is a vehicle remote positioning device with built-in GPS and GSM, GPRS technology in compact size. It can transmit the longitude and latitude coordinates to your cell phone by the SMS. By this, you can find its location on the Google maps? Or other map software. The tracker uploads positioning data through GPRS to a designated server. The user can look for real-time location-tracking, historical trajectory through the Internet. Guard against theft of strongbox, vehicle and outdoor equipments, cargo.
- Features:
- Built-in SIRF Star Chipset, excellent for fixing the position even at a weak signal status. Work well even in areas with limited sky view like urban canyons.
- Built-in GSM, GPRS module, support GSM 900, 1800 MHz.
- Support voice call.
- Support SMS communication or GPRS TCP connection.
- Get the position information via mobile phone SMS, or examine the path on the Internet.
- The available SMS takes the control command change tracing function or switch GPS.
- Support establishes three telephone numbers. SOS button send out exact location for immediate rescue, action.
- One key for easily use.
- The major technological index of the device is in conformity with the international standard of GSM mobile phone.
- Portable, compact size, low power design.
- Support cut-off electricity and oil function and recovery command
- Support electronic fence function
- Caution:
- Please read the handbook carefully and operate in right way, to avoid anything wrong;
- The installation of this product suggests to the professional taxi firms, to ensure the safety of the using and hidden of installation.
- The picture in the user manual may be different from the real products. Please follow the products. It is not separate explained.
- Specifications:
- GSM module: MTK program, GSM 900, 1800 dual-band; Support the TCP protocol
- GPS Chipset: SIRF-Star III chipset
- GPS Sensitivity: -159dBm
- GPS Frequency: L1, 1575.42MHz
- C, A Code: 1.023MHz chip rate
- Channels: 20 channel all-in-view tracking
- Position Accuracy: 10 meters, 2D RMS
- Velocity Accuracy: 0.1 m, s
- Time Accuracy: 1 us synchronized to GPS time
- Datum: WGS-84
- Reacquisition: 0.1 sec., average
- Hot start: 1 sec., average
- Warm start: 38sec., average
- Cold start: 42sec., average
- Altitude Limit: 18,000 meters (60,000feet) max.
- Velocity Limit: 515 meters, second (1000knots) max.
- Acceleration Limit: Less than 4g
- Jerk Limit: 20m, sec
- Operating temperature: -25 to 70 Celsius
- Humidity: 5% to 95% Non-condensing
- Voltage: 12V~24V
- Build-in GPS+GSM module
- Antenna module (GPS+GSM integrated)
- 4-pin cable
Edited by mr33gts4
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
