Hey all,
Well I finally received my R33 and have now had it for about a week. I am absolutely stoked with it. It's been a while since I drove one and I couldn't belive the effortless power...even in standard form (what my car is at the moment). 180km/hr @ 4900 rpm...piece of cake. I was really surprised to see a turbo timer and CD stacker in teh boot, 2 things that I didn't know about.
I have changed all the oils:
Shell Helix Ultra 5W-40
Shell Fully Synthetic gearbox oil
Shell LSD Diff oil
I must admit, before I changed the gearbox oil, the shift from 1st to 2nd was notchy but OK. Now with the new oil it's REAL crappy. Once the gearbox warms up it's not too bad but still not acceptable in my book. Gathering from old threads, a lot of you have experienced the same problem. I was thinking about adding Nulon gear treatment before I change the oil again...Any Thoughts???
Some of you have commented about the oil pressure with Helix, I am happy with the oil considering the price, oil pressure is OK.
I have added new wheels and a K&N replacement filer. I think she needs a boost though, I'm getting used to the power already :)
https://www.sau.com.au/forums/topic/26861-finally/
I previously posted on this type of notchiness.... What I did was add oil stabiliser to the box (Lucas recommend 20% if the gearbox is not too worn) and it smoothed the box out nicely.
Others have used Redline Lightweight Shockproof oil. This is a bit more of an expensive way to go. Someone pointed out in reply to my post that oil stabilisers were just oil thickeners, but Redline is simply a thicker oil (80w120). Also, it was mentioned that oil stabiliser (Lucas) was subject to foaming, but at the end of the day, the quality of the gear shift is to a large degree a measure of how well the oil is working.
Teflon treatments such as Nulon and Slick 50 seem to worsen the gearchange as far as I'm aware because they work too well, thereby diminishing the effect of the synchro rings.
Try draining your oil and mixing a 20% mix with oil stabiliser and it will only cost you about another $20 bucks or so - definitely worked well on my box which was still notchy after a re-build.
Incidently, I've heard from a number of guys that the notchiness is not necessarily a reflection of the condition of the box. Mechanics I've spoken to say some gearboxes remain notchy no matter how carefully you re-build them.
https://www.sau.com.au/forums/topic/26861-finally/#findComment-567075
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
