they are definately not advan RS. They are advan RZ.
Try search on google if you want.
The differents are the spoke, shape, and the color.
the spokes are more aggresive/curvy than advan RS, and this racing hyper silver color is new color from Advan japan, they are not the same
as silver Advan RS. These are more shiny than regular silver, and are more expensive than gunmetal color.
awsome rims. these are different to the RS because the spokes are grouped into pairs. it's very subtle but when u see them in real life you can tell. my mate just brought a set over from Japan for close to 5k (beter width and offset), but these are definitely worth the money
