Got a Gold Cressida that i use as a run about. She's automatic and slow but does get from A to B no worries. $18 to fill the LPG tank and i get between 330-370km's out of it. Also has a switch to run petrol which gives that extra bit of power
And speaking of power... it has super light power steering too!!! Interior is in quite good condition for its age and the STEREO system pumps hard out of the in-dash central speaker. A true Pimpin' Chapel Street Cruiser
I've driven it since June and haven't had any problems apart from a couple minor things (locked myself in and out a couple of times, i'll fix the lock before selling it), forgot to check the radiator water level and the temp rose past half way, so had to wait half an hour at the supermarket carpark and treated her to a $3 natural spring water top up.
It's registered till May next year and i'll grab a RWC for it too. LPG
conversion was done in 1997, and new windscreen not long ago. I've got all the receipts from what's been replaced and any work done on it.
Could do with a coat of paint, but for this sort of car i wouldn't bother... just get the high pressure cleaner onto it every once in a while to remove any clear coat flakes
So if ya after a second car or something to tie you over till the paper work is finalised on ya brand newie... this could suit you!
$900
Cheers,
Andrew
hahaha... fair enough! I wish i had mates that would buy me cars :rofl:
I don't have any pics at the moment. But I'll see if i can get some tomorrow. Have to see if i can borrow a mates digi cam and email them on to ya.
Cheers,
Andrew
it's reliable... just a bit slow. It miss fires a bit on cylinder 6, but i've driven it like that for 3 months now with no problems etc.
I've been offered $800, and would like to get rid of it ASAP as i don't really have the space for it now.
Andrew
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
