Hey people,
Just wanted to get some peoples opinions on this, maybe find out what i would actually need to do in each case... I am currently putting money away for one of these ideas.
1. I have always wanted an R34 GTR. So in a few years i could just buy one straight out, possibly get it imported if the currency is behaving.
2. I am considering just doing a turbo conversion on my R34 GT, making it a GT+T. What parts would i need for this and how much am i looking at? I am assuming that after everything is done, including labor and parts and everything, it would cost around $10000???
3. Someone on here gave me the idea of doing a complete engine swap. Then i saw another member selling his GTR V-Spec II engine for $8800 or something like that. So my last idea is to buy a GTR engine, and put it in my GT. DO NOT KNOW ANYTHING about this sort of thing though lol, so would the engine fit, what problems am i looking at, who in Perth would do it for me, etc?
Any thoughts or suggestions would be appreciated,
Cheers :)
https://www.sau.com.au/forums/topic/269291-engine-swap-or-turbo-conversion/
uuuusually to budget for a engine conversion you budget 2 to 3 times the cost of the engine to put it in.. but as this is a 26 replacing a 25 the engine part of the conversions shouldnt be too much or too hard, but all the supporting components will have to be brought up to spec, ie driveline, transmission, brakes etc..
for instance i got quoted $16,000 to put a s6 13btt in my mx5, the cost of the engine was $3,500.. and this was by the best workshop qualified to do this conversion.. the reason the price was soo much was because the only thing that was going to be mx5 at the end of the conversion was the shell..
You could build a engine for $8800 and it would be better then a Vspec engine
only advantage vspec has is the 24u block? (i think)
or you could buy a rb25 half cut for around $3500-4000 then swap it in should come well under 10k
as for buying a R34 GTR you can just save up but it would resale better then your current modded/converted R34
however if you want boost now a engine swap would be more sensible
hmmm engine swap would be teh way to go cause the GT+T would be high compression + turbo hmmm its ok i guess but wouldn't be able to pump high horse power....i did and engine swap mine was NA stuff started to break....e.g gear box etc so i hadd to replace everything sooner or later even did a 5 stud conversion and diff etc......lots fo money wasted if i had a choice i'd sell out and buy a GTR too :) hope that helps
Save your money and get the GT-R.
If your paying a workshop to do the whole lot, you'll be paying out the ass, It won't be the same as a GT-R and you'll have all the other issues with a modified car. Plus you wont get any of your money back when you eventually sell it.
A stock 34 GT-R wont make all the strange noises, will be easier to sell when youve finished with it and will generally be nicer.
My 2c.
have u considered selling ur gt and buying a gtt? ull save more money for sure. then have fun with the gtt while u save for a gtr. but if its the gtr motor u want for now, get many quotes and go the swap.
what i think would be the best idea is.. grab a gtr motor but keep ur rb25 motor around and when it comes to buying a gtr u can swap ur old rb25 back into the gt then sell it as a whole? then ull have ur sic gtr motor to wack into the new gtr. plus u can sell the stock gtr motor that comes with the car.. ya dig? just a thought
Edited by 1R34SON
Well if i sold the GT and bought a GTT, i would be spending about $10000 just to get the same mods i have on the GT... I might just leave it NA hey, see how much power i can get out of the RB25DE without wearing it out too much. Then get they GTR in a couple of years
You spent 10k in mods on a non-turbo? how? why?
Have a look at the Naturally Aspirated section of the forum, there are people in there who, for some unknown reason, love their N/A RB's.
My opinion, cut your losses and stop wasting money on the non-turbo.
Yeah, the fact is dude, not to rag on you or anything, but if you don't know how to do it yourself it's EXPENSIVE to get someone else to do it. Generally cos you always get these stupid little issues that slow things down, then you cant get a part, then your cars in their garage for a few weeks, *goes downhill*
Did you spend 10K on minor engine mods, stereo, kit and rims? Or was that 10K all engine work?
Sell the GT, get a GTT or save money now and get a GTR soonish. N/A is silly if its a skyline. Remember whatever mods you put into a car expect it to not increase the value of the car by much at all. aka Money Pit
listen to this man :D
how much is an R34 NA manual worth? 11-13kish?
sell it, buy R34 GT-T, few years buy GTR
best bet
I was going to convert my NA R33 to turbo, but realised it'd be cheaper to sell and get a GTSt.
Could have sold it for $9k, but unfortuately only got $8k for it because someone hit the side of it.
Bought my new 300hp Series 2 for $15k, only a $5k difference for better brakes, suspension, engine, more power, better body, and better interior.
Just save for the GTR
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
