hey all after upgrading my kit and changing to a dump+front pipe im selling the following S1 parts
3" Front pipe to suit stock dump pipe, no gaskets included. i think its stainless steel but the heat has changed it toa light brown, also has a light graze underneath.
$100
Mspec front bar, stock white, mint condition, does not come with indicator wire connection clip, but comes with wireing, a connection clip will need to be sourced, should be easy enough from another nissan.
$200
Mspec? sideskirts, stock white, condition is a bit rough on the edge along the doors, a respray might be needed for the fussy.
$100
Stock rear bar, stock white, good condition apart from a small paint crack that i touched up seen in the pics, a respray will be needed for the fussy.
$100
Aftermarket GTR grill, not painted, never fitted.
$50
Parts are for pickup only, im in SE suberbs melbourne.
https://www.sau.com.au/forums/topic/269296-fs-r33-mspec-bodykit-front-pipe/
$100
$200
$100
$100
$50
Is there any chance you could send the grill to mackay, I know you said pick up only though i thought i would try
  • 4 weeks later...
items are still for sale
ADDED
o2 sensor origional
i thought my o2 sensor was buggered but when i replaced it nothing changed, so im assuming the origional o2 sensor is still fine and for sale - $30 pickup
ADDED
2 inch split dump pipe, bought from JJR, i have hand filed out the split pipe hole properly as they come a bit smaller, only seen 100km as upgraded to 3 inch bellmouth
$100
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
