Item: 1999 Nissan Pulsar N15 SSS Manual
Website: Carsales, Here
Item Condition: Very good!
Reason for Selling: Want a R34 GT-T Coupe :P
Price and Payment Conditions: $8500 (or swap for R34 plus cash)
If anyone wants this cheaper:
-$200 I keep Pioneer Headunit
-$150 I keep Subs + Box
-$100 I keep Mono Block amp
Extra Info: I have had this car since Nov 2007 and it has been the most reliable car and a pleasure to own since then.
I can assure you it hasn't been mistreated, as I am one to appreciate a well looked after and well done up car, not thrash it.
149,xxxkm
Also being a Pulsar and all it's got quite good fuel economy. I average about 9L/100KM and get about 450km from a tank which only costs $45-$50 to fill up! (98 octane fuel)
It has some tasteful modifications such as:
*17" Ozzy Racing Rims in Blackened Silver finish
*Talon Side Skirts + VZ-R Rear Pods
*Genie Extractors + 2" exhaust to 3" dump tip
*K&N Panel Air Filter
*Tinted Windows
*Short Shifter
*Lowered suspension on Pedders
*KYB Shocks rear, Pedders front
*Sway Bar
*Cup Holders (handy)
Audio/Electronics
*Steal Stopper Remote Central with Alarm/Immobiliser
*Pioneer DEH-P6050UB with iPod Connection (have iPod hiding draw under headunit)
*Alpine Type R 6" splits (front)
*Alpine Type S 6" (rears)
*2x 12" Pioneer 800w Subwoofers Boxed
*Kenwood 400w 2ch Amp (For powering fronts)
*Kenwood 1000w Mono Block (for Subs)
There is NO rust anywhere on the car and has not had any major problems since owning it.
If you have any questions or would like to inspect the vechile don't hesitate to give me a call, But please, no 'tyre kickers or test drivers'
Thanks for your time.
Contact Details: 0412 125 191
Pictures: P4190359Medium.jpgP4190342Medium.jpg
OLDER PICS when I had it in NSW:
