I’m in the process of installing a Boost Controller / Turbo Timer / Boost Gauge. I need to know if my 1990 R32 GTR has a Single or Dual ignition wires.
I have attached the best photos from the installation guide & it’s all the info I have. I’m stuck on where a few wires go if any one can help?
I’m guessing it’s a single ignition so I’m going to following the instructions for the single ignition set up.
I’m stuck on the following wires
The wire that goes between the relay terminal 86 & the Parking brake. Do I join a wire from the terminal to the hand break switch or do I cut the hand break wire & wire that to the terminal on the relay. Basically I need to know if it's wired in series or parallel. I'm guessing it's parallel & it's just to get an earth when the hand brake is applied?
The Yellow wire "switches the unit on & off" & is wired to the ignition this wire I'm really not sure about. Does it go to the ignition switch if so where on the switch. Or can any positive power that comes on with the ignition like the cigarette + be ok?
The Red +12VDC provides power. This wire needs to go to Battery positive does this mean it must be wired directly to the + terminal on the battery so it’s always on or can I wire it to a positive such at the cigarette lighter +
Any help would be much appreciated?
https://www.sau.com.au/forums/topic/269487-r32-gtr-single-or-dual-ignition/
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
