hey guys,
mate and i bought a written off shell in s.a no pannels at all.
using the motor and box
have rear tail lights $50 each
headlights. $250
all interior
Dash $300
all peieces in mint cond pm me what you want.
centre console $80 with everything.
dash surround with clock and all $80
boot surround $20
Seats $200 pair
rear seats $80
Carpet mint $150
seat belts set of 4 $200
steering wheel $50
Sunroof rooflining $80
Sunroof $150
All plastic rear pannels $20 each.
parcel shelf $50
Tokico struts and springs $400
ABS booster and master $100
Clutch master $50
Subframe complete minus diff and shafts $250
Cross member $100
LCA $150
Brake and hub convo $850
pm me what ever u need thats not up here mite have it.
will get pics tonight.,
located in s.a
cheers ben
0416 640 060
https://www.sau.com.au/forums/topic/270384-wrecking-r33-s1/
the whole inner boot surround available? i'm very keen
also willing to sell an r33 manual conversion kit (no box, but everything else?) unless you're using parts?
im in SA too. pm me >_<
https://www.sau.com.au/forums/topic/270384-wrecking-r33-s1/#findComment-4604335
hey looking for the clips that hold up the sunvisors to the roof mine broke can u let me know how much and a pic plz pm if able
sure do call 0416 640 060
have u got boot carpet?
still have the brake and hub convo package??? I am chasing the front and rear calipers rotors and hubs if possible
yeah mate still here ull have to organize shipping though.
im in SA too. pm me :D
can do the following parts:
New master
2nd hand slave
Clutch pedal and brake.
Gear boot and manual surround.
rear tail shaft
not sure if you will need the dash surround but will through in also.. minta :P
$500.
Benny, Still waiting on those pics of the headlights, i need them ASAP!!!
sold sorry
do u have a leather handbrake surround? if so how much. plz PM
yeah $30
Hi, is the sunroof complete with rails?
Yeah mate sure dose.
dont get on here much best bet to message the number.
cheers ben
https://www.sau.com.au/forums/topic/270384-wrecking-r33-s1/#findComment-4620807
front brake shims?
no sorry
Hey mate, what condition is the drivers seat? Any rips, stains or wear marks?
driver seat has minor tear were your right butt cheek would sit in top corner.
sms for pic..
I'm after the drivers side power window switches and 'control box' that's inside the drivers door. do you have those?
got the switches but auto up not work.
also got the control box..
sms me for price.
mate i'll take drivers side tail lights if you'll post - at my expense of course
yeah sure do sms for price and pic.
cheers ben
0416 640 060
https://www.sau.com.au/forums/topic/270384-wrecking-r33-s1/#findComment-4626443
  • 2 months later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
