  • Replies 60
Ill b there, yeah i parked next to u today Maximus. The guy with the white series 2 R33 told me he'd be there too, but i dont know his name, he could even be one of u guys.
Good idea about parking next to cams
I think its a good place to meet initialy, if there ends up being a few cars we can always head somewhere else at 1.15pm or so.
Everyone who is going should try to park along the back row on level 3, it would be good to have as many cars as possible next to each other.
hehe, im the only dude in the eng carpark that sits in their car and studies :)
man...good luck parkin in the back row at 1pm
chances are there are gonna be no spots
wat i was thinkin is that we can initally meet up there, but then go to somewhere more open, socialise there instead. i just thought it might be easier for everyone
Yeah thats what i meant too....
Ill b there well b4 1 so ill get a spot, everyone else can fight it out. I got a spot there today at 12 no probs, still 32 parks left.
Was a good turn out, nice to meet everyone.
Unfortunately had to leave to go and do some uni work/waste time on internet. :D
But ill definately be up for going on a few cruises now ive met a few people.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
