Standard FJ20 (including both stock manifolds, turbo, injectors) + 5 speed manual gearbox with clutch and flywheel. Never saw it running but was told it was running fine when I purchased it for my project. $1200
HKS cast exhaust manifold fot FJ20 $300
180sx 1994 rolling shell black - was written off for unknown reason at some stage. Has all glass and used to have an sr20det. Has doors with glass, front guards, bonnet, lights and some sort of aftermarket front bar - throw me an offer.
Alternatively I am looking to sell 180sx front panels which will ocnsist of guards (either used stock or used vented wider fiberglass ones), standard bonnet, standard lights and an aftermarket front bar $500
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
