FOR SALE - Air flow meter from my 1999 R34 GTT (think they fit the R33 GTS-T as well)
It works fine I just got a new ECU and there for have no need for these anymore.
Asking $100.
Feel free to PM, Email [email protected] or Call on 0424323434 (Dan)
https://www.sau.com.au/forums/topic/271623-r34-gtt-air-flow-meter-for-sale/
  • 3 weeks later...
  • 2 years later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
