Hi guys,
Here's the story in short.
Normally on my PC, i click on my user name and then enter a password to gain access to windows. That happens after the WINDOWS Loading screen.
Now,
1) My PC crashed.
2) I removed the hard disk from the PC and bought a casing for the hard drive so i can transfer the data over to a new computer
3) I have files stored on the DESKTOP of the old PC. I can't access these files from the new PC because it says Access Denied.
4) Is there anyway for me to retrieve the files on the DESKTOP of my old PC? Which directory are they saved under?
Thanks guys!
https://www.sau.com.au/forums/topic/271798-computer-gurus-please-help/
What version of Windows are you running?
Basically what you need to do is take ownership of the folder, then give yourself full rights to it.
In a nutshell, Normally you right click on the folder, go to the properties of it, go to the security tab, click on the advanced button, go to the owner tab, add your new account as the owner (it may give you a warning about replacing the ownership), once this is done, close the windows and go back to the security tab, add yourself to the list and give it full control. You should now have access to the folder.
Edit: Desktop folder is located in your profile folder under c:\documents and settings
This is based on Windows XP but should be similar in Vista.
Edited by Deano45
I'm running windows XP pro.
The thing is, i can't access Windows via the hard drive, i can only access the files inside the hard drive. I understand about giving rights and all, but i can only do this if i can access to the Admin's Control Panel right? Which requires me to log onto the Windows in the old hard drive.
Okay let me do a quick situation analysis:
So you've got your OLD HDD with your screwed up Windows XP on it in a caddy that you can plug into another computer and you wish to get the files off the OLD HDD but it's telling you access is denied in certain folders, is that right?
Solution:
If so, you can take ownership of the folders on the OLD HDD as long as you're an Administrator on the other computer on which the HDD is plugged into.
What do you mean by your "PC Crashed" ? It might be an easily fixable software error.
If you need more help feel free to ask here.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
