Hey fellow sau members i just finished with a half cut and have alot parts left ova
of list below
SYDNEY pick up only ... sorry too busy to stuff around with posting stuff
I have most pics i need find my usb cable to add but if interested ill send u a pic asap
FOR SALE
2x front coil overs stand nissan( seem alright ) $30 each
washer bottle with motors $ 30
strut brace r32 front $50
2x r32 N/A floating calipers+brackets $20 each
R32 RB25NA head( is striped cept valves and springs) $200
-178k wear on them
-cams In + ex $ 80
-cam gear in and ex $60
- rocket covers ( painted matt black) no gaskets$100
R32 25NA block not touched after removed-- $200
R32 auto starter motor ( worked when removed) $40
Airconditioning lines + compressors x2 $40 for lot
r32 blinkers lh and rh $ 20 each
r32 head lights lh $40
r32 head light rh cracked at front $ 15 ( if anyone wanted to fix glass)
r32 auto tail shaft - diff to gear box $40 ( no bolts supplied comes as 2 parts)
r32 na exhaust manifold+ heat shield and o2 sensor$ 90
r32 accerater pedal $15
r32 power steering pump+ bracket $40
r32 dash surround behind steering wheel auto (prnd321)$15
r32 alternater $ 40
r32 radiator auto $ 50
r32 toque converter (auto) free( not sure how good it is)
r32 AUTOMATIC transmission FREE to pick up.. input shaft stuffed*( been sitting out side for 9 months
r32 auto seleter $20
r32 blue turbo cluster 94k on speedo $ 90
r32 air flter box parts+ some piping $15
r32 standard front lower control arms $ 40 each require bushes
r32 engine fan rb 25 $ 30
r32 Intake manifold rb25na $90
r32 l/h and r/h engine mounts $50 for both
r32 rb25 na fuel rail and injecter wiring $50
r32 standard pipe manifold too the cat $40
r32 POD filter cover red it came off so it fits $60
r32 2x fan shrouds $15 each
r32 master cylinder $100
r32 brake master cyliner $60
r32 horns x2-$10
PM ME FOR ANY REQUIRES
  • Replies 50
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
