  • Replies 41
I'm glad to hear AustPost got some through and unless you are outside of their next day Express delivery you all should have one by end of day.
I am sorting out a refund for Houghy as there was a misunderstanding (it won't fit an R32).
1. themeaton (payment cleared, posted, received)
2. aberax (payment cleared, posted, received)
3. moobaque (payment cleared, posted)
4. keymaker (payment cleared, posted)
5. houghy (payment cleared, posted, received)
6. 08r3308 (paying next week)
7. StageaTypeS (payment cleared, posted)
8. nismor32gtst (payment cleared, posted)
9. lastarfighta (payment pending)
10.
11.
Mine just bolted straight into my R33, top stuff :D thanks for that, trader rating left.
Edited by Aberax
4. keymaker (payment cleared, received)
9. lastarfighta (payment cleared, ready to ship today)
10.
11.
posted lastarfighta's brace today.
9. lastarfighta (payment cleared, posted)
10.
11.
i have mine firmly pressed against the master cylinder (maybe 1/2 turn after finger tight?!) but make sure you re-check and tighten it as the firewall may flex back a bit with use. really you should only need enough to ensure the hat is held against it.
as long as the master cylinder can't move it should be fine.
glad to hear lastarfighta.
08r3308 you should have yours Wednesday, i forgot about the long weekend here so it didn't go today.
There are still more braces available.
6. 08r3308 (payment cleared packed ready to send 9/6)
9. lastarfighta (payment cleared, received)
10.
11.
6. 08r3308 (payment cleared, posted 9/6)
10.
11.
checked with UAS and still some master cylinder braces available.
3. moobaque (payment cleared, assumed received)
6. 08r3308 (payment cleared, received)
7. StageaTypeS (payment cleared, assumed received)
8. nismor32gtst (payment cleared, assumed received)
10.
11.
Edited by wolverine
10. Darrin Spencer (payment cleared and sent)
11.
pm's sent weeks ago to 1FSTKR and rocketboy.
i can see you have logged into SAU but haven't checked your pm's yet, if you are still keen i can send them to NZ while the GB is open.
Last few days before this closes.
11. KiwiRS4T (payment cleared and ready to send Monday)
12.
13.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
