Thats not a 400r Dash, it is a Multi Function dash (MFD) run by an Epson unit. They are extremly hard to near impossible to find any parts.
What is wrong with it?
search for epson and should pull up some links with what a working dash looks like
here is one link to get you started
http://www.skylinesaustralia.com/forums/Ch...ml&hl=epson
fixed , just a loose wire.
thanks
every time i see one of these units i start to cry.
when i got my car it had one of these in it.. the dude told me the screen was for a japanese GPS system and was useless in Australia.. he offered to put in a stock cluster for no charge, so i agreed (didn't want a big bloody useless black hole in the middle of my dash)
THEN i joined SAU, and found out how rare/sweet/easy to setup they were. FML :)
  • 1 month later...
Dont be so sure, when i had mine i tried to track down where they came from and i know that the epson was never sold as a retail item hence wht they are so hard to find now, i did find some info that led me to believe that they came out in the R33 400r, the dash its self tho was then and still is now sold by nismo there is a few of those around.
Yeah their crazy it took me like a year and half of hard searching to get the complete kit for my car!!!!
Have you got yours in and running yet, any problems?
