I've recently picked up a '93 R33 GTS (JDM model)
I've had it for a couple of weeks now, but my headlights blew out...
I replaced them with brand new H1's but only 5 min after installing they blew out again (%^#$$!!!!!!!!) :action-smiley-069:
I've noticed the brightness of the headlights fluctuating since I bought it and think that might mean something
any advise??
I'm not sure if JDM models need different bulbs or if it's an electrical problem...
..... It's probably the latter but just thought I'd get a second opinion
https://www.sau.com.au/forums/topic/272357-r33-headlight-issues/
  • 3 months later...
It sounds like your alternator's voltage regulator is broken. They often start overcharging your battery when they wear out. Use a voltmeter and check the voltage of your battery while the car is running, if it is anything over 14.4V or so then the regulator needs to be replaced. If the alternator is overcharging then you are lucky that the headlights have blown before the more expensive electronics in the rest of your car. Get it checked/fixed before that starts happening or it could get very expensive soon.
The other thing if you didn't know is you have to make sure you don't touch the glass bits of your headlight bulbs with your hands/fingers. The oil from your skin causes a heatsink effect on the bits you touched and this will greatly reduce the bulb life. I don't think it'd be bad enough to cause them to blow within 5 minutes, but keep it in mind anyway. If you accidentally touch the bulbs, wipe them clean with metho or something before installing them.
people seem to exagerate a bit on the touching of the bulbs. the first time i changed bulbs (back when i was 17) i touched the glass (was holding it by the glass to put it in the plug) and they both still worked when i sold the car about 4 years later. i have probably touched the glass in some way on every bulb i have ever installed (some cars you have little choice due to the way they go in, but i don't hold them like i did that first time) and i have never had a headlight blow or anything like that. the current set i have had in the car for probably 6 years and i'm sure i would've made some skin contact with the glass when either getting them out of the packaging (cause it was really hard to get out) and putting them in.
however you are pretty spot on with the alternator voltage regulator. first place i would be looking.
oh and all r33 skylines are JDM models.
There are 3 things that blow globes
1. Over charging Alternator
2. Poor quality globes
3. Vibration
Often with overcharging the blown fillament will be stuck to the inside of the glass.
Past experience of being an Auto electrician for 18 years.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
