* Hello, i am selling my R34 skyline, it has 53,000km manual, always serviced every 5,000km it has 18 inch mags with 80% tread, 3 inch turbo back blitz beer exhaust, adjsutable coil overs aftermarket front mount intercooler, all engine is stock, has a pod filter on it, full genuine GTR front, including front bar, bonnet, front flared guards, xenon headlights. selling because i would like money to buy a supra, will also swap for a twin turbo supra
LOCATION QUEENSLAND
Price is negotiable, looking for a fast sale.
0439676614
http://www.carsales.com.au/all-cars/privat...&__Qpb=true
Edited by vice5500
https://www.sau.com.au/forums/topic/272401-r34-gt-t-manual-for-sale-20400-ono/
  • 1 month later...
DONT BUY THIS CAR!! BEWARE vice5500 IS F*****G DODGY !!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
