  • Replies 54
Posted Images
In regards to the variable intake, is it stilled hooked up and functioning? I imagine it would make a large difference with boost as well. Except IMHO you could get away with it being actuated and open fulltime by running constant 12v feed to the solenoid :banana:
tuner FAIL big time.
he was sick so it didnt go in yesterday :)
dont know when he will be back + when he is, he will have to reschedule me in which is more time loss.
booked in at another tuner tomorrow.
will be ready by the weekend.
can't wait.
dyno sheets etc up sat if all goes well.
Dan, afaik, the variable intake valve will function as normal on a NA (ill have to speak to my tuner about it first).
Nate, it still hits the front bar :)
will decide that shiet out later, will do my best to make it fit without cutting my sexy gtr bar.
the way my turbo sits, i was still able to use a bit of the stock NA intake > afm pipe which is a bonus.
i will definately get a custom pipe from the throttle body to the intercooler pipe as 1) the stock crossover one is so ugly and 2) the BOV just barely clears the power steering resevoir so i had to move it further down.
can't wait.
shiiiiiiiiit.... hoped u would have been cracking in the 200's now......
soon mate... u will drive out of the tuners with the biggest grin on ur face :cheers:
Dori, check your phone, sent a few shots at different angles of the front bar/piping, hope it helps :P
With using the N/A intake pipe, is that going to work with the air box that you have? or will that need to be custom re-made? i found the JJR one to not fit so well on my N/A. I had to bend the side where it runs near the aircon cylinder (not sure of the technical name for it, it's next to the canister) and also had to unclip the canister and have it sit a bit lower. The part from the turbo to the AFM was fine though, just not sure how that's going to go with the N/A intake.
DOR134 is out and on the road, it made 201rwkw :ermm:
nate, did u get the 33 or 34 airbox cover? if its the 33, then yeah u had to mod abit to fit but for ashneels group buy, he redid the prototype so it fit R34 as well ;)
tuner said its got tgrouble holding boost up high in the revs but so far ive revved to like 5ish and it held 10-11psi fine - running straight off the gate (10psi spring) and no boost controller yet.
just found out that the braided oil line is leaking oil :@ back to pirtek i go to get it fixed up so hopefully i can get that done tomorrow morning.
love the ext gate & screamer, car feels 10x better then it did before :P
BOV is blocked atm so i got hectic doses and fluttering atm, hopefully can get a hose and plumb it all back up tomorrow coz i dont like the flutterssssss
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
