hey guys i wanna get rid of a huge amount of stuff i have accumulated during the build of my R32 and a couple of mates cars.
as always will post anywhere in aus AT BUYERS COST.
item: oil cooler with braided lines (no sandwich plate)
suits: any car
condition: good but used
price: $90
item: big bosch in tank fuel pump
suits: any car i spose came out of my R32 (will need very slight modification to the cradle as it is pretty big)
condition: good never had any hiccups or anything
price: $50
item: Stock R32 gts-t turbo
suits: any car with a T3 exhaust flange
condition: held up fine at 12psi
price: $150
item: RB20DET afm x2
suits: any RB20
condition: both good
price: $75 each
item: Stock R33 turbo
suits: any skyline/ T3 flanged car
condition: No idea never ran it came off of a RB25 and a new HKS turbo was put straight on.
price: $100
item: RB20/25 Dump pipe
suits: skyline turbo
condition: good
price: $30
item: RB20DET block
suits: any car
condition: has been honed and decked but needs oversized pistons
price: $50
item: RB20DET head
suits: rb20
condition: engine head gasket so could just need decking or could be cracked
price: $20
item: R32 GTR Wing in Black
suits: Any R32
condition: Good
price: $100
pm me or call/msg me on 0421 308 872
thanks guys
jono
https://www.sau.com.au/forums/topic/272701-r32-parts-up-to-my-earholes/
ill take your R33 turbo for $60 EFT im on the gold coast, plus ill pay postage
price on the r33 turbo is $100 or you could go to SSS automotive and all the others and pay $300+
as i said i dont know bout its history so thats why its cheaper
suits: any car
price: $90
price: $50
price: $150
suits: any RB20
price: $75 each
price: $100
condition: good
price: $30
item: RB20DET block
suits: any car
price: $50
item: RB20DET head
suits: rb20
price: $20
suits: Any R32
condition: Good
price: $100
thanks guys
jono
very intrested in the afm
where you located?
if u can call or msg
on 0450782472 would be easier
thanks bud remz
is this guy actually interested in selling anything... ive pm'd him twice with no response....
c'mon seller...... lets get crakin...:P
  • 4 weeks later...
do you have a good cond rb20det complete head 4 sale
the head i have is in questionable cond (dunno coz it was off an engine w/ a blown head gasket) $50
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
