GTR R32 1989, immaculant gtr going around no dents scratches or any imperfections. well looked after inside and out. gtr r34 rimz with new tyers, twinplate clutch, power fc djetro and hand controller, 700cc injecters,sound system, surgetank and external 2nd pump, tein adjustable suspension, always serviced and very clean motor, rarely gets driven. must be seen
MELBOURNE 0415158159 FOR ANY QUESTIONS. NO TYER KICKERS
https://www.sau.com.au/forums/topic/272908-gtr-r32/
Hey,
Couple of questions.
What colour is that? Look like green-ish with some sort of pearl or I'm completely blind?
Still have standard turbos on the motor or has it been upgraded?
Cheers
https://www.sau.com.au/forums/topic/272908-gtr-r32/#findComment-4632501
well spotted the colour is infact ford ego, it has been professionaly painted inside and out i also removed all the windows be4 painting (show standard). i still have standard turbos they are holding back what the motor can really do.
https://www.sau.com.au/forums/topic/272908-gtr-r32/#findComment-4634512
  • 3 weeks later...
  • 1 month later...
price drop $20,000 (gtr r34 rimz, power fc, sard injectors NOT included)
so the new owner has to tow the car away now?
or u gonna put a stock ecu , stock injectors and stock rims back on .
what boost did u have this car running at?
https://www.sau.com.au/forums/topic/272908-gtr-r32/#findComment-4767408
Maybe you should list more info about it... in that engine pic alone I can see that it's got (all unlisted) pod filters, after-market alarm, sway bar, adjustable suspension and ABS.
https://www.sau.com.au/forums/topic/272908-gtr-r32/#findComment-4767456
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
