Hey guys,
did service on car, changed fuel and oil filters, oil and trannie oil. opened air flow meter and cleaned air filter car running smoothly be4 hand but just in need of change. After complete turned car on as normal... idled fine... although as went to rev, it spluttered and acted as though it wanted to die.
also is the airflow meter prongs ment to be soldered inside the flow meter.
any ideas would be heaps apreciated ?????
CHeers Josh
https://www.sau.com.au/forums/topic/273060-r33-gts-4/
I had to replace my AFM as mine stopped working (suspect due to using an oil-type pod filter). I ended up sourcing a 2nd hand replacement off someone wrecking their car on the forums - For reference it's the same AFM on NA as Turbo.
Cheers
chicane
Edited by chicane
https://www.sau.com.au/forums/topic/273060-r33-gts-4/#findComment-4644292
Cheers
chicane
id have to disagree. the NA and turbo AFMS are deffinitely different. GTST computers dont like NA AFMs, and likewise. different part numbers
https://www.sau.com.au/forums/topic/273060-r33-gts-4/#findComment-4653736
  • 3 weeks later...
I have an AFM from my r33 gts4 n/a if you want it.
It has the pink label on it and was working fine when I took it off.
I thought something was wrong with it so I bought a new one, turns out it was fine the whole time. Massive waste of money on my part... but I was planning to change it anyway as a maintenance thing.
If you want it pm me :-)
https://www.sau.com.au/forums/topic/273060-r33-gts-4/#findComment-4686393
Hey guys,
CHeers Josh
Just a question, what filter are you running?
When you cleaned it did you put too much oil on it? or are you running one of the dry apexi filters?
Apparently if there is too much excess oil on the filter it gets stuck to the metal prongs in the airflow and will cause the airflowmeter to give a faulty reading.
The other thing is to clean your throttle body as it can get dirty and cause the rough idle etc, you'll be suprised at all the junk in there especially if you're running an aftermarket filter without a box.
I'm not a mechanic, these are just some of the things I have discovered since owning my r33. I work for toyota and a few of our mechanics own skylines (traitors I know haha) so that's who I grab all my info from... they haven't led me astray yet :D
https://www.sau.com.au/forums/topic/273060-r33-gts-4/#findComment-4686402
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
