G'day,
Is there anyone on the Sunshine Coast who would be willing to let me have a look in the back of their Stagea? I'm possibly interested in a ~2000 RS4 but I am having trouble visualising the boot and I am only going to get one if I can fit dual dog enclosures in the back (I don't need rear seats) - a cargo barrier won't be suitable :down:
At this stage it's only a "maybe" as I'm considering utes as well but Stageas... Well, who wouldn't want one?
So possibly I wont need to bother you, but possibly it would be handy!
https://www.sau.com.au/forums/topic/273405-sunshine-coast/
How big are your dogs? Just to give you a rough idea about how much space there is in the rear. With the seats folded forwards a queen air matress fits in the back (inflated, duh) It molds around the strut towers and fits pretty much perfectly.
https://www.sau.com.au/forums/topic/273405-sunshine-coast/#findComment-4639919
A 45kg German Shepherd and a small Husky (20kg). The problem dog is the GSD, as he is a working dog (security) and gets hyped up very easy and starts destroying things so he needs to be in a fully enclosed metal enclosure which is why my Falcon Sedan is not suitable. The husky just goes to where your feet go and happily sits there being lazy.
Going by those sizes, I think a Stagea will suffice. I can get someone to design a cage that fits in with the seats down and is removable so that way I can use my back seats if I really want to :D
It is just over 36", 920mm, between the wheel arches. For that reason alone I bought mine.
Ohhh, that's a handy measurement. Based on that, I can get a cage constructed without the seats down to secure the GSD, then the Sibe can just sit in the front/back in the leg well or whatever it's called.
Now it's time to convince myself this is more practical than getting a ute :)
https://www.sau.com.au/forums/topic/273405-sunshine-coast/#findComment-4640961
Can't edit my post but in my searches I came across a 2003 M35 for 16k, that seems a bit less than what most are going for?
http://carsguide.news.com.au/site/search/v...p;vehicleType=1
Also a 2001 RS4 which seems to be a bit lower than average:
http://www.drive.com.au/used-cars/NISSAN/S...849043&pt=1
Are these cars priced lower than average or has everyone else suddenly jacked their prices up as I started looking? Both of those are through the same dealer.
https://www.sau.com.au/forums/topic/273405-sunshine-coast/#findComment-4641234
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
