ok boys like the tittle say i start a new project on my r32gtr
what is already on my car -turbo back 3inch exhaust with 4inch pipe
- apexi intake filter kit
- greddy 4inch fmic
- greddy alu upper rad pipe
- megan lower rad pipe
- koyo alu rad
- deral electric fan
- greddy cam gears
- greddy pulley kit
- act clutch 6 puck solid hub
- flywheel toda
- starter is rebuilt
-autometer gauge boost,water temp, oil temp, oil press, volt
now what i plan to put : - r34 nur spec longblock
- nismo motor mount
- splitfire coilpack (my ignitor is brand new also)
- greddy ic piping
- oil catch can
- new turbo water/oil line
- all hose and wiring harness
- r34 camshaft position sensor
- tomei exhaust manifols
- garret 2860-5 turbo with new wastegate
- rebuilt the alternator
-remove hicas completly
- respray the engine bay
and the question is: -can i run these turbo with other stock component ?
- does i need an ems or fuel management injector fuel rail fpr to have a
good air/fuel ratio?
-does i need something else to had a reliable setup? really dont want to
blow my new engine!!
- an what is the SAFE amount of boost an hp that a stock n1 longblock
can take?
- an the redline start at? and rpm cut off is at wich rpm on a stock n1
engine??
i want clear answer of people that have already done a setup like this
thanks!!!
https://www.sau.com.au/forums/topic/273413-new-setup/
N1 internals in all honesty are not much better than RB26. They still suffer from virtually ALL of the short comings of the standard one.
You'd be better off rebuilding and putting a decent set of pistsons/rings and so on in there.
Stock rods are OK. -5's IMO are the wrong turbo for a stock motor they are 370-400rwkw turbos, a stocker bottom end wont take that forever
https://www.sau.com.au/forums/topic/273413-new-setup/#findComment-4639801
ok so wich turbo is the best if i want to keep the stock internal.... an r34 n1 turbo??
i have a budget of 20 000 25 000 canadian dollars for the whole project
https://www.sau.com.au/forums/topic/273413-new-setup/#findComment-4639809
20k Canadian = 22k AUS - that is a very healthy budget.
For 22k in AUS you could get a very reliable 380rwkw setup.
Forget N1 motors mate. Not worth the price in any way shape or form IMO.
If i was you, i'd contact a AUS/NZ builder and crap the N1 motor idea.
Have a motor put together ~ 10-13k should get you something delivered with pistsons, new crank, prepped rods/decent rod bolts and a bit of a head tidy up all assembled and ready to go.
It could well be cheaper, i have no idea on freight charges but i would imagine around that.
Then you slap the turbos, exhaust (you really should have 3.5" or more), management... other things like injectors, AFM's, oil cooler and so on then get it tuned.
The second half would roughly be 8-10k AUD - so about 8.5k in your money overall
That would slot into your budget and you would have a motor that is leaps and bounds ahead of the Nissan factory faults
https://www.sau.com.au/forums/topic/273413-new-setup/#findComment-4639818
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
