Item: 1993 R33 Series 1 Skyline
Item Condition: Mint
Reason for Selling: Need a family car, and just lost my license so need an auto for the better half to drive me around in lol.
Price and Payment Conditions: $13,000
Extra Info: Car is in excellent condition with 95,xxxk's, FMIC, Boost gauge, Duel stage boost controller set at 6psi and 12psi with in car switch, HKS SSQ Bov (really loud and nice), 18" rims, everything works and freezing aircon, ABS, interior condition is perfect. Probably a bit more, pm with any questions.
Pictures:
https://www.sau.com.au/forums/topic/273572-93-r33-series-1/
  • 3 weeks later...
bump, PRICE DROP TO $12,000 lose my license in 10 days, need gone, any offers? car just serviced and 6 months rego will be put on next week.
Edited by bradnkaila
https://www.sau.com.au/forums/topic/273572-93-r33-series-1/#findComment-4744938
Best cash offer ?
still has rego???
really looking no lower then 12k but make an offer, still rego'd atm, driving while i can! current rego runs out next week so will be renewing for another 6 months
https://www.sau.com.au/forums/topic/273572-93-r33-series-1/#findComment-4745529
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
