Hey mate
I have a R32 GTR shell ( no engine , g/box, seats ) most the other stuff is there ( has suspension, rear cradle and diff, windows, back seats, wiring, all trims and so on ) Its not rego's or complied , its silver, 1991 model i think will confirm that.
Chasing $5000 for it
Im in Adelaide
https://www.sau.com.au/forums/topic/273582-r-32-shell/#findComment-4641416
Hey mate
Im in Adelaide
thanks for the offer mate a little far away and really only need a shell to replace my bent one thanks anyway
https://www.sau.com.au/forums/topic/273582-r-32-shell/#findComment-4641429
mainly just sill and bottom of the rear quarters... the shell itself is pretty straight etc it was a drivable car
all depends what you need with the shell... take it to pm
sorry mate cant pm yet but working on it
https://www.sau.com.au/forums/topic/273582-r-32-shell/#findComment-4641505
still looking
Hi Matt
Sorry for taking a while to get back to you I have been just trying to work out he best way to go with the car as there have been a couple of options and a few different people asking.
If you are keen how quick would you like to move.
So I can give you a price please confirm what parts you require and optional. From out phone conversation you mentioned the below, please advise if I missed anything
Shell including
Front & rear windows & side windows
Brakes & hubs
(Brake Master Cylinder?)
Rear Cradle
Optional
Doors
Boot?
Tail lights
Regards Taylor 0408188777
https://www.sau.com.au/forums/topic/273582-r-32-shell/#findComment-4689408
