maybe its stolen car?
probly not, but if you want to sell your car why not put in the effort of telling everything about your car and that will make a quick sale
r33 12400okms
quick sale ,
front mount, pod filter, ebost2 controler, coilover suspention, bigger fuel pump
Fail
https://www.sau.com.au/forums/topic/273643-r33-5k/#findComment-4646957
Take a close look at the photo - the paint on the roof appears to be shot, and there are quite a few dents and minor damage, not the sign of a well looked after car .....
Looks like frost on the roof but the side damage is clear.
Awaiting response from the thread starter.
https://www.sau.com.au/forums/topic/273643-r33-5k/#findComment-4647140
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
