Items for sale:
1) 12 inch boss sub in enclosed box with boss amp $150
2) monza oil catch can $30
3) electric oil temp gauge $30
boost gauge $30
autogauge brand or $50 for both
4) massive drift carbon fibre wing $180
5) fibre glass r33 bonnet with hood pins $350
Please pm me or call me on 0432741088
im willing to negotiate, and swap for r33 parts, mechanical parts, no audio thanks. :)
Edited by GHO57
https://www.sau.com.au/forums/topic/273654-skyline-parts/
EVERYONE!!!!I DONT HAVE A CAMERA ATM, IF YOUR REALLY INTERESTED CALL ME AND I CAN ORGANISE TO DRIVE TO YOU OR MEET SOMEWHERE, THANKS!!!. But i will do my best to fix my camera and post pics up thanks.!!!
https://www.sau.com.au/forums/topic/273654-skyline-parts/#findComment-4643564
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
