rb25 turbo engine & gearbox combo
engine has 140 000 kms
all standard inc turbo and cooler
still in car so can hear it running
full engine with manifold and turbo loom and conputer gear box will come with all cylinders and pedal box
can include tailshaft if necesary
comes with everything you need
$3200
or will seperate if a buyer is found for both,
*will be wrecking a full 33 if these sell so if you chasin anything in particular let me no
https://www.sau.com.au/forums/topic/273936-fs-rb25det-engine-and-gearbox-3200/
What year is the 33? S1 or S2
Where is the car damaged?
the car isnt damaged anymore it just needs touch ups and prep work and a spray job i just cant be bothered with it anymore, you may remember a little while ago i advertised the full car with the damaged back gaurd.... well a new back gaurd was fitted and the car is now straight but i have really lost intrest now and want to part it out so the engine and gearbox will be sold first then the rest,
or if someone wanted to buy the lot i would sell it cheap!
  • 1 month later...
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
