hi all yer i no it not a skyline like all my other cars have been so i got this sc,300 for sumthing new been having a lot of fun with it and a lot of moods have been doen as
1 2jz bottom end 3L
2 mines cams
3 mines ecu with a pigyback apexi afci
4 sard fuel reg set to 60 psi
5 5 speed man starght cut gears
5 single turbo conver t4 gt45 turbo
6 50mm external wastegate
7 turbosmart bov
8 80 mm front mount 700x500x80
9 manelly raceing forg pistons
10 bosch 044 fuel pump
11 brase botton triple cushion heavy duty clutch
12 torson lsd
13 hks cam wheels
14 2l surge tank
15 gates timeing belt
16 500cc injecters
17 3" straght throw exhust into twin hollow cannons
18 droped 2.5"
19 front side back body kit sitting 1.8" of the ground
20 retrimed leather interier pissed of wood dash and door cards
21 s type 6x9 in back with s type 6" in front with alpine comp head unit
dyno she got 589 hp on 14 psi
at willowbank talion took it down the 1/4 mile and ran 12.4 @118mph on 10 psi
Edited by gonzo
https://www.sau.com.au/forums/topic/274246-my-new-toy/
just talking to a spraypainter soon she will be painted ( blueberry )with candy gliter black roof boot and bonet how does that sound a bit of a girls colour but i want to do sumthing diffrent lol and dont worry ppls them 17 r gorn sold em for 200 lol now iam running on r34 gtt stock r16z lol
https://www.sau.com.au/forums/topic/274246-my-new-toy/#findComment-4666410
  • 4 weeks later...
  • 3 weeks later...
  • 5 weeks later...
  • 4 weeks later...
    • My 3.8 kW system (when new, not so much nearly 20 yrs later) will do 21 kWh per day (best few months of the year), and that's with an afternoon shading issue. So it really could/should be able to do maybe 24. So a 6.6 kW system probably cannot fill a 40ish kWh battery from scratch, but then it is very unlikely to ever need to. Let's presume that you use 10-15 kWh during the day and stash the rest. So long as the battery isn't drawn down below ~50%, it'll be fine. And that draw down presumes using 20 kWh overnight, which is a reasonably heavy draw. So that seems reasonable. The 40kWh will be good for extended outages, and very bad days where you get almost no generation for a day or two. Might struggle to top it all the way back up after it gets pulled all the way down though. I'd think you'd probably want about 10 kW of panels to make life a little easier, wrt keeping a 40 kWh battery charged. But then....does it really need to be at 100% every day? Probably not.
    • Am I wrong in thinking that there is a hell of a lot of battery storage for a 6.6 feed into it Your battery is around 4 times bigger than the battery that is going into my place in a week, but I have nearly twice the feed Will the batteries actually ever get fully charged? School me on the science bitches
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
