Hi all,
I have for sale:
Apexi front pipes for R32/R33 GTR (Off the dumps measure 2.25', at the cat measures 2.75', fitting has been attatched previously for oxygen sensor) $300
Nismo clutch pedal bracket to suit R33 GTSt, brand new $180
Nismo FPR to suit RB and SR setups, brand new $160
Tomei metal exhaust manifold gasket, brand new $80
N1 Oil pump gears, brand new $300
R33 GTR recirculation piping $120
GTR BOVs with mounting brackets $200
RB25 head (including cam, timing and valley covers) minus CAS $550
RB25 block, crank and crank cradle (number 6 piston blew a ringland) $150
R33 GTSt calipers, rotors and pads $550
R33 GTSt climate control unit $50
R33 GTSt diff (non abs) $200
R33 GTSt driveshafts (pair) $50
R33 GTSt front and rear sway bars $20
R33 GTSt condenser $50
R33 GTSt HICAS unit $50
Earls Oil cooler and relocator kit with braided lines to suit RB setup $500
Hawk brake pads for R33 GTSt, brand new. Front $100, Rear $80, Pair $150
HKS BOVs for RB26 $50
Motul RBF 600 brake fluid $15
B&M Oil cooler cores, brand new. Each $120, Pair $200
Stock R33 GTSt flywheel (will require machining) $50
Cooling Pro 40mm radiator to suit R33 GTSt/GTR, brand new $250
Parts are welcome to inspection.
Prices are negotiable to a degree.
I am located in Sydney, I am happy to post interstate at buyers expense.
https://www.sau.com.au/forums/topic/274379-the-anything-and-everything-sale/
  • Replies 47
Hi all,
I have for sale:
will you sell the hawk pads for 150 delievered to perth.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
