Hi,
Joined this forum a long time ago as you can see from my join date, but finally getting a R34 GT-T end of next week If the car checks out all good ;)
Anyone know much about 999Automotive and their pre-purchase check? was going to do it through RACQ but found 999 and figure its better with people that know imports a bit better :thumbsup:
https://www.sau.com.au/forums/topic/274600-hi-brissy-sau/
Woah thats a weird hour to make a post like this but anyway congratulation on your purchase and I'm sure you'll enjoy it as much as everyone else here. I'll be doing my service at ERD. Maybe ask Dan if he can do a pre-purchase check as well. Down to earth and very friendly bloke. Cheers
https://www.sau.com.au/forums/topic/274600-hi-brissy-sau/#findComment-4654845
Heh at work at the moment 4 day x 12 hour shifts ;)
https://www.sau.com.au/forums/topic/274600-hi-brissy-sau/#findComment-4654846
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
Ă—
Ă—
