18/06/09 Baskin's Meet With A Twist Of Car Detailing!
  • Replies 294
pls send videos to [email protected] :)
We'll msn later
so is mine but its my cars last week with this turbo setup so not driving far :)
and you can wash her josh we will watch you :(
I dont wash cars. Mine has mud up the side of it. It'll stay like that until it rains.
yeh dan and mick (white r34) treked it from the gold coast
thats commitment to bnr
yeh boy, this shit is getin serious..
next time we have to find more tables and chairs..
oh, lets make sure no ones cars get hit by someone elses doors LOL
Yeah was worth the trek and good to meet some of the sau boys.
Wont be makin it this week cause im in a far away land working but will come up again for sure the week after.
And yeah hopefully no 6000 year old ppl open their doors into any more cars :(
How long did u stay at the car wash for after we left?
fingers f**ken crossed i will be driving by then.. oh, of course, got my new shell, wheels, coilovers.. all the shit together, this shit is happening bros. I will be her first wash :sniff:
U meaning this week or next?
What do you guys think about the clear LED tail lights on my car?
Check out how much shit I copt for them on boostcruising :down:
http://www.boostcruising.com/
Just click on the pic of my car (Second row down on the left) an it will take u to all the comments
Edited by Danski
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
