I'm thinking of getting a white on black background personalised plate for my white 33 gtr but I dont know if the slimline or the standard will look better on the car. Anyone have any recommendation? Or should I go standard on the back and slimline on the front? Cheers
Brandon
https://www.sau.com.au/forums/topic/274770-personalised-number-plate/
Going off this website I assume the slimline ones are called 'prestige'? If so, seems pretty similar to the front plate on premium plates in NSW, if that's the case I reckon it would look great on your car.
I've got slimmer plates on the front of my car and I'd say it wouldn't hinder the airflow to the intercooler as much as a standard plate would (even if the difference is only marginal). I just put some longer bolts and spacers between the bumper and the plate so that I didn't have to bend the number plate...
Ive got the same plates but black on white. They're definatly good looking and make a car stand out;
Maybe you could get "GTR 24U" :P
Had to be quick to snap up those plates eh mate? Good effort!
I think that cos they're both only 5 characters they also just fit the JDM lic plate holder nice and snug right?
Have had them for a while now actually :P
Yeah your thinking is correct, they both fit the rears perfectly, no need for trimming at all
slim line make a big difference imo, well worth it, finding a good combination is harder unless u go prestige. I got Blue on silver, slim front, standard back.
Looks like a perfect fit! What are series is that though? I've got different side indicators comparing to yours. Why is that??
Series 1 or 1.5 (1995) , (series 2 motor), modded front bar though, I removed the middle section (where the plate is now)and filled the cutouts,
Edited by hardcorz
Yours is a GTR isn't it Brandon? the front bumper/spoiler, front indicators and side indicators are all completely different to a non-GTR (GTS / GTS-t)
Yea it is. Just that I've never noticed that difference until someone offered me the side indicators for free only to find out they're totally different.
But yea, I'm settling for white on black. Placed the order yesterday. I've also took the carbon blade off for sanding and getting it recoated. The previous bastard who did it just recoated the faded coat without sanding it down... looks like crap and got some massive clear that's cracking from probably birdshit. 1/3 done!!! big job to just sand the bugger down (you'll see white powder when you start and yellow when you're through the top top and finally CARBON!).
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
