lol, problem solved.
Ok, Tuners in Sydney, i am looking at selling a set of rims soon to get a Pfc + Z32 and fuel pump. is there many that are good with the Pfc and can tune quickly?
Cheers
Buy a Vi-PEC...no need for a z32 then...Call Scott at Insight for ECU and tuning. If you must buy a power fc see Jim at Croydon for tuning.
Basicly i'm looking for 270kw max, will the Vi-pec do the job and is it cheaper. I'm looking at Buying a GTR down the track (afew yrs) so i want to have a good power output in this car to get me through and also want the cheapest option (but has to be able to handle some stick) so i am open to cheaper ECU's as long as they do the job.
Cheers guys
Ill be gettin my pfc and goodies tuned soon also. Was goin to see Justin at Blacktrack but i think they've move or sold up shop. He used to mainly do Rotary's but said its more half half now.
Problem with going to sydney is dont you need to leave it over night or something for the cold start tuning??
majority of time when a PFC is installed into a stock 25 the cold start is correct straight of the apexi setting's
If the air flow curves have been adjusted then yes cold start will need to be tweaked as will the rest of the map
Other then that it is plug and play
Its not in Newie but Mark @ DAT Performance is good.
Located at Tuggerah - 43536664
i wouldnt recommend them as they melted my mates piston on the dyno, he got a call from them saying it had leaned out and to bring a tow truck pretty much...
  • Nope 1
Yeh thats fair enough, i guess they would. But i suppose if i have problems during cold morning starts can always take it back or something for tweakin etc.
I called Justin from Blacktrack about 2 months ago and he said he would do it, must of changed his mind. lol.
Well cameron let me know if you come up with somewhere to take urs to get tuned.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
