Welshpool & O'Connor u can just rock up and have an inspection, but for East Perth, Warwick, Midland and Kelmscott you need to book.
The cops only have to find one thing wrong with your car to defect it, but then again the police do abuse their powers so your car doesnt really have to have anything wrong with it....
  • Replies 70
this ruling went out about 3 years ago
ruling is now 1.25
ie:: r32 gtr stock runs 16 x 8 equates to 16x1.25 = 20 //// 8x1.25 = 10
therefore a r32 gtr can legally now run 20x10 rims
this was explained to me by Reno the head guy at welshpool pits when i got my gtr registered with 17x9's on it
so a gtst stock is 16 by 7 so we can go to 20 by 8.75 max legally. is this right?
stock gtst rims are 6.5 i think.
Im pretty sure the constitution leaves road rules to the states? Meaning that a national code of practise isnt going to be valid unless the states have forfeited their constitutional rights to govern this?
I got that info off the state site, its quite possible its outdated, but it seems odd it would still be up if it is.
Maximum passenger car tyre and rim width
Tyres fitted to passenger cars or passenger car derivatives must not be more than 30% wider than vehicle manufacturer's widest optional tyre.
The rim width must not exceed the recommendations for the tyre fitted.
For example, if the original widest optional tyre is 185mm, the maximum tyre width is 1.3 times 185mm = 240.5mm, ie a 235mm wide tyre. The maximum rim width for a 235mm tyre is 9 inches if the aspect ratio is 60 or below.
NCOP11_Section_LS_Suspension_and_steering_3Feb2006.pdf this is downloadable from http://www.infrastructure.gov.au/roads/veh...n/vsb_ncop.aspx
Page 17 has a table to help. check it out.
Edited by StageaGirl
found it my guess is that it would be the 45 in 235*45*17
Aspect Ratio:
When buying a rim that is larger than stock, you must change the aspect ratio of the tire, too. This will keep your speedometer reading correctly. When you “upsize” your wheel, the aspect ratio will be smaller than stock. This gives your wheels and tires a wider contact patch, improving cornering ability.
Using a smaller than recommended Aspect Ratio means you have less rubber to absorb impact that can damage your rim. It also reduces the amount of contact your tires have with the road.
Using a larger than recommended Aspect Ratio increases the ride height, and will make your speedometer read slower than actual speed. It can also cause rubbing in the wheel wells. It affects steering stability, and will make your car feel floaty when cornering.
Edited by Pal
When is your car booked in at Joes Mr. Auto? I'll go to his shop and swap em over for the day :P
I'm calling him in a little while (just woke up... I'm a bit of a nightowl because I work late nights) to sort it out & I'll let you know.
I'm perfectly happy for you to grab em (I'll be dropping it as early as possible in the morning) as long as they're properly back on the car when I pick it back up :P
Don't want any of this lol
Edit: PMing you details
Edited by Psyrus
i got stickered yesterday in collie for my camber wear on my tires an they made me get my car towed back to bunbury at my cost of $250 i wasnt happy one bit,
does anyone know the rules of ride height might just take it to a dodgy garage an give em a carton :) jk
does anyone know the rules of ride height might just take it to a dodgy garage an give em a carton :laugh: jk
What is it with cops giving stickers now and saying tow the car... that is as good as a red sticker which have not been around for years and years...
I would like to know the law that says they can do this, as they are suggesting that you must now tow the car to the mechanics to get fixed and then to the pits before it is drivable...
Technically they could only make you tow it if the wear on the tyres was that bad that it would be dangerous to continue driving. How bad the camber wear is depends on that, but in this weather maybe it could have been justified....
However to do that, really the yellow sticker should be timed & dated to when they write it up, leaving no other option but to tow it, otherwise they can let you drive off again, pull you over after 20m & fine you for driving with an expired yellow sticker ~$600....
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
    • Yep, cheapest options, neglected and abused. The fastest way to dislike a car is to get assigned that model by a budget rental company
    • The noise complaint could be from absolutely anywhere, and anyone. Get it actually noise level tested to find out if you're actually over, or if you're fine. If you're over, quieten it down. If you're under, carry the test results in the car with you.
    • SAU NSW x Benzin Cafe Cars & Coffee Sunday 12th October 2025 7:30AM Meeting Benzin Cafe Meet Location: Benzin Cafe Dural RSVP: https://forms.gle/Q9TcFu9DHe4dbvtKA   *Disclaimer* One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
