In what?
Hydrolic lifters wouldn't find it amusing,
should net a nice amount of power extra though, eith larger TB and free flowing exhaust
Its going in an rb25de neo....how much are solid lifters these days? and wat size piping you think will be best i have 2 1/4 now im thinking 2 3/4. Cheers mate
RB25 neo's already have solid lifters, not sure how much lift they can handle though. They also have crappy exhaust cams, i reckon you'll get a decent amount out of it with some cams.
As for exhuaust, its really depends how much power you think you'll get out of it... a free flowing (mandrel, good mufflers) 2.5" really should be enough to be happy at ~ <160rwkw N/A (mandrel, good mufflers etc). Not sure how much you can get out of 2.25", but i'd guess if you were making much more than ~ 135rwkw, you'd want to increase the size.
If you have future intentions for nitrous, boost, or some more serious N/A work, 2.75" wont hurt anything, just for that extra resolution (car will be happy <200rwkw).
What other mods do you have? Done anything with intake? What about management? Cams like that are going to feel fairly flat without a tune, either a piggyback that handles ignition (like emanage ultimate) or full management.
i have
-cold air
-2 1/4 exhaust
-high flow cat
-emanage ultimate (not installed yet)
is the 2.25" mandrel bent?
If not, I wouldn't change it just for the hell of it, do some other stuff first and when its tuned, your tuner should tell you if there is too much backpressure, and if its whats choking your engine.
Can emanage ultimates alter VCT? As that will definately need adjustment for cams with that duration.
But yeah, in a nutshell, your car will love those cams with the gear it has. When you get it tuned, you will see if its being choked from the intake or exaust.
If i was you, as a next mod i'd put twin throttle body's on your intake manifold, shouldnt be too hard since it has the twin input Y peice as it is.
Granted its higher capacity, but with alot milder cams (255/8.3), my 30DE with twin 60mm throttle's, uses every last bit. Also, with exaust, it had 2.5" press bent, with a 2.25" section (decat pipe), it made 150rwkw, but tapered off quickly, it always felt flat after peak power aswell, after i fitted a 3" mandrel exhaust (2.75" wasnt available) that was no longer an issue and it held power strong until limiter.
Its not mandrel bent and not sure if you can alter vct with emanage and wouldnt vct go with new cams?
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
