Hey!, Well I don't have a skyline, but I do have an S30 that's getting real close to finding itself with an rb25 nestled inside, and i was told this is the place for RB info...
that said, i also plan on eventually mating an RB head to an L block, mostly just because, but also for an engineering project i'm eventually going to have to do for school...
thanks all
https://www.sau.com.au/forums/topic/275550-hey-from-the-states/
Welcome! Some of the S30's in the US are pretty balls out. Although... RB head on an L block is gonna be tough though, simply because they're very different engines other than both being inline 6's. Stroke the L to a 31 or 32 instead.
post pics of your car(s).
I'm from the middle of indiana... right where the ohio and missippi rivers meet... flooding is always fun...
anywho, yeah the RB head has the same head stud location and same size as the 20/25, and it's going to be a 3.05 ish, since i'd like to only punch it to 88 instead of 89 so it'll handle a turbo a little better... the motor is going to be run on a haltech ECU at any rate and going to be Dry sumped so that pretty much removes the need for the front cover as it's for the chain, oil pump and dizzy, and mine is going to have none of those...
the oil galleries are close ish (enough to where it can be modified) and the water passages are also relatively close, close enough to where there isn't anything that a mill and welder cant fix...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
