Item: R33 stuff.
radiator support panel ,cut behind strut towers $250ono
cross member (k frame) $150ono
steering rack complete from ti rod to ti rod $180ono
steering rack minus passanger side rack end and ti rod end $100ono
series 1 head lights a pair $300
series 1 rh front bumper blinker $30
dash pads x2 , 1 coverd in genuine white swade $250ono,1 stadard $120ono
series 1 steering wheel $40ono
series 1 front seats $100 a pair
rear seat x2 $50 each
set of 5 aus approved seat belts $150
set of 4 door cards $200 i also have other single door cards $60 each ono
set of 4 inner door/roof molds $100set
hood lining x2 $40ono each
carpot in mint conditon $80ono
kyb suspention $350ono
rear cradle $150ono
rear upper and lower control arms lh side $100ono rh side $100ono
rear hubs complete with brake calipors, lines, hubs, rotors $220ono
front sway bar standard $50ono
rear sway bar standard $50ono
front hubs and rotors $150ono
tail lights and covers x2 and i have 3 colours 2 chose from ,white,marone,red $150 a pair has bolb loom with them as well
x4 power window motors x2 lh and x2 rh $60 each
rear bumper covers and suport bars x2 $100 ono each
series 2 boot wings x2 $120 each in white and 1 in marone
boot lid with shaved boot lock lil ding $80 ono
space saver wheel like new tyre $100ono
set of glass minus front window has tint $250 for the set i paid more just for rear window at a inport wreakers
lots more stuff i will add when i rember or just ask if there is sum think you need i might have it cheers
Location: tweed valley i can deliver to sum places as i work all over the gold coast
Website: here
Item Condition: great
Reason for Selling: not needed
Price and Payment Conditions: as above but make offers
Extra Info: just ask if needed
Pictures: can get but only on dial up atm
Contact Details: here
https://www.sau.com.au/forums/topic/275656-lots-of-r33-parts/
  • Replies 45
sorry to pll that have pmed me i cant return a pm till my topic cound reachs 10
i do have the a/c pipe skibbo
to thoose who pmed me i pnly have rh side fron lower control arm x2 no lh 1z sorry
the marone boot wing i looked at today has sum clear pealing but yeh i can post at your cost cheers
yeh ill post power window motor for $65 if your keen punisher6942
i should have those triageler plastic bits aidan make offer
isoru yeh still got sway bars ,sorry silbastian dont no if they fit r32
sorry still cant pm ppl so if you want these parts pm me your number and part you want and ill give you a call cheers
sweet as dude ill take one of the drivers side power window motors off ya hands for sure. Text me your bank details and ill transfer the funds when i get your details. My number is 0423819988 and the name is daniel. Ill look forward to hearing from you mate
n/a beast (james) give me your numba and ill give you a call cheers
punisher ill give you a call tomos cheers
sorry ppl i still can pm due to post count no being 10 or sum crap
Edited by DRB25
hey DRB25 still waiting on that phone call or text message with ur banking details champ..... and just want to clarify that the power window motor is in 100% working order???
Hey mate,
Can you give me an address to come and see the car? jus wanna have a look at headlights and some other bits and pieces. The headlights will fit my R33 GTS series 1 aye?
My mobile number is 0402859795.
Cheers mate.
I live in Southport
hey mate its skibbo here my number is 0415554917 for the big ac hose from fire wall to compressor how much to send to sydney all up cheers mate sydney 2753
Edited by skibbo
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
