Hi Guys,
Need some new tyres and need to pay some bills, so got some spares I'd like to offload...
R32 - Guys, got a 3inch cat-back kakimoto exhaust that I just recently pulled off my r32. I put louder cannon style exhaust on that the only reason for removal. The kakimoto flows more then the exhaust I have on now (couldn't believe it). It has an oval muffler on the rear, with mid muffler and it very quiet on idle and cruising but under load it really screams. It is definitely a legal exhaust.
- Does not include Cat -
$300
R33 - Also have an custom made turbo back exhaust off an r33...Includes stock dump onto 3inch front pipe (no cat) the 3inch all the wat to the rear cannon).
This exhaust has very minimal bends, and has a different design path to eliminate as much bends as possible. because of this you cant just bolt it up cat back to another style of front pipe, it wont line up. It flows VERY good, sounds very tuff to (its loud).
$Offerss
R33 Diff 4.11 ratio non abs $250
R33 bonnet s1, orange colour, few tiny scratches. Good to paint black for that Jdm look $80
R33 front doors, driver's is missing window winder motor otherwise complete with glass minus door cars $100pair
R33 front seats and rear seat, good nick (a bit of cat hair though). $200 for complete seat including rails..Good to use for older cars for a nice modern look/upgrade and some slight bucket to hold you in place.
pick up only Sydney West.
email me at [email protected]
Cheers
Daniel
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
