Ive been tryin to find a nice set of rims for my 33 n/a. i did find a set on tempe tyres, but they r only 17's ans dont come in 18's, which is wat i want to go for.
does any one know of any sites that have rims to suit n/a skylines (4 stud)?
cheers,
https://www.sau.com.au/forums/topic/276254-rims-for-na/
  • Replies 44
cheers,
http://www.stgeorgetyres.com.au/
http://www.tempetyres.com.au/
dunno if NSW have a tyre factory but yeah, try there too
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4676860
There are rims out there, you just need to know what you want and know how to find it.
Ditch searching from Tempe. What's your budget?
Something along the lines of these suit your criteria of 18 inch 4 stud.
18x8.5J+29
18x9.5J+29
http://page12.auctions.yahoo.co.jp/jp/auction/p140223242
Alternatively if you're dedicated you could do the turbo brake upgrade, and have better brakes with a larger variety of 18" wheels to choose from.
-Jimmy.
Edited by -Jimmy-
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4677251
Finding 4x114.3 rims isn't all that hard ...
Finding 4x114.3 pattern wheels to clear turbo brakes on the other hand is pretty hard ...
im doing the turbo brake upgrade on my R32 using the R33 gts-t calipers and rotors redrilled to 4x114.3 but ya need some huge offset wheels in order to clear the big calipers or ya need like 25-30mm spacers to fit them
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4677298
i have 17x9 +15's in 4x114.3 all round, clears the 33 gtst brakes on my 31. :)
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4677573
oh yeah, importmonster.com!
Rip off, their fees are ridiculous. Trying to search on that site doesn't show you half of what's on there most the time too. Using a translation of auctions.yahoo.co.jp is the way to go, and then get Jesse Streeter to get them for you.
www.jessestreeter.com !
Edited by -Jimmy-
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4678640
thanks guys,
i might try some of the places around newy, bob jane and all them.
my budget is about 1000-1500, im only an apprentice so cant afford all that much.
i have been thinkin about the 5 stub conversion and brakes and that, but a) i havent got the money for them b) i wouldnt know where to start to find them or put them on and c) this is my daily drive so it cant be off the road for more than the weekend.
i have a good idea of the style i want, these r on tempe tyres, but r for turbo'd lines.
either in shadow like this or chrome. have asked tempetyres but they cant machine them to find 4 studed lines
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4679247
look around for multi studs so if you ever do decide to upgrade brakes or sell its win win
yep..
you'll probably find most of the better size/offset rims are multistud anyway.. both the sets i've had that clear 33 brakes were.
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4679677
thanks every one for the inputs.
Line 3- they r mad rims but not the stlye im goin for, i must be hell picky haha
Hank scorpio- where can i find Work and Volt rims, i have seen Volt rims on some of my mates cars in sydney, they dont look to bad.
as for a picture, the missus reset the computer for some reason and she only saved her pictures, so i havent got around to takin any more, im pretty 100% sure it is the same as Line 3's skyline, but a light silver colour
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4681262
