I'm a little confused, are you still trying to see if the coil packs are bad? If so, the quickest way to find out would be start the car and then disconnect one coil pack at a time. If there is no change in engine idle when you disconnect the coil pack, thats your bad one.
Also are these the same coil packs that are on R33 and R32 skylines? If so I should be able to track down a set of used ones for fairly cheap. Anyway let me know.
lolololololol, mate ive been a mechanic for a quite a few years and i never thought of that hahhahahhahahahahahahahahahahaa
im absolutly ashamed of myself, ill get it done
kiwi - yeah its completly blocked off mate, it solved the problem straight away, well for the stalling issue anyway,
xmetal - i know its not the bov making it idle rough as its block, the bov was the sole problem to my stalling issues when we 1st got the car
mate i reckon its your cam angle sensor. had very similar symptoms with my 33 and ended up being a cam angle sensor. put splitfires in before i replaced the sensor and fixed it a little but once the sensor went in she was sweet. give it a shot if you've got one handy.
