Is there a Q45 AFM "option" in the PFC??? I havn't looked at my PFC for a few years.
If not, is it alot of work to re-calibrate/tune with Q45 compared to Z32's?
Obviously there is a wiring/plug change.
What year AFM's should be looking for?
Cheers
Justin
Edited by XRATED
https://www.sau.com.au/forums/topic/276649-rb26dett-pfc-and-q45-afm-tuners/
GTR powerfc does not have the option for Q45, it can however be done if you have datalogit (inputing q45 maf curve into z32 option).
If you get stuck email me your map OR if your unable to get it done locally and need to drive it to the tuners express post the ecu and i can do it.
Edited by URAS
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
