just sent my car in to have it stereo finally put in. below is what going inside.imnot good with model nubers so ill post them here later.
the New Elipse all in one DVD deck.
Eclipse 6" splits
eclipse 6" rears
2 4channel fusion powerplant amps (500RMS each) Speakers
2 2 channel fusion powerplant amps (580rms each) Subs
2 12" fusion powerplant subs. in a fibre galssed boot.
2 2 faren capacitors
2 head rest screens 5 1/4"
shit load of sound dedener.
i think thats everything.
the boot is getting a custom mold (no spare tyre). fusion green
i'll conferm all the power outputs and model numbers sometime this week. dont pick if there rong.
ill get some progress pics and the final product when done. notice the key word "when"lol
https://www.sau.com.au/forums/topic/27683-new-stereo-pics-when-finished/
I am not trying to have a go at anyone, but I just have not seen fusion perform. If its the right price yeah go for it. I am not at all trying to say i have the best stereo around, no where near it, but for example, the Fusion WRX just made 140 db with 3 15's and a hell of a lot of power at the 2003 jamboree. I would have thought it may have performed a little better.
My car got 148 db with two 12's at jamboree, and i had a few bugs that i have been iorning out.
Honestly good luck man, i hope it all works out!
Happy Stereo-ing
well its everyone to their own .. its their car so they can do what they like .. i agree that fusion is probably not the best for power and spl and even sq for that matter ... but u gotta agree that their green aliens are pretty cool :) .. but yeah in car audio theres always something thats better than something else ... if u really wanted some power u'd try and get some adires and all these other american brands u've never heard off ... well i can't wait to see this install ... should should kick my pissy diy install :(
Originally posted by Fhrx
Should sound nice. :wave:
Why two caps though?
I thought you need 1 farad per 1000wrms. that setup is around 2000 wrms looking at the amps (580x2 + 500x2 = 2160wrms) thats a lot of power. I'm running an mtx amp with a 0.5 farad cap, no diming lights! :cheers:
Sorry if i offended or pissed anyone off. Just saw he was using eclipse hu and splits and thought must be goin sq setup, that's why i was kind of curious about why the fusion gear?
the fusion 12" powerplants perform really well if your after nice booming bass. i aint going for spl as my box wont be ported im just going for a big bass (if that makes sence). the eclipse splits and rear six inch's will compensate for the sq. sq is my first priority as it is a dvd deck. i'll be in adelide a few weeks after its finished and in warnambull next weekend (if its finished) so if anyone want to see give us a pm.
my ford has a 1 12" powerplant in it and i was quite happy with the results i got from that. 133db. ported box though.
i might of forgot to mention it before but dont quote me on the outputs and stuff. as for the caps.... 1 per sub will make sure it hits hard and strong first time and every time. ill get the exact specs hopefully to you today but most likely not until sometime next week. :cheers:
Originally posted by Evil
I thought you need 1 farad per 1000wrms. that setup is around 2000 wrms looking at the amps (580x2 + 500x2 = 2160wrms) thats a lot of power. I'm running an mtx amp with a 0.5 farad cap, no diming lights! :(
With all due respect, dimming lights are a sign of bad system wiring and caps are a band-aid fix for a bigger problem.
Before you start buying caps, you need to have a good look at the wiring in the system. Then take a look at the charging system and power storage. If there is a problem, upgrade the battery and alternator before buying a cap. :P
You're right. But there was no dimming before the cap. It was just added just in case and the battery although not deep cycle is not standard. Some people with yellow tops and upgraded alts still run caps. Dimming lights are a bad sign but it doesn't happen to me :D All the wiring in my car is perfect (I've had a lot of practice) and also the wires are nice and short. Caps are only a band aid if you are having problems with dimming light before you fit 'em. But you are right if you are having electrical problems then look into the other parts first. A cap may not even help!
  • 5 weeks later...
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
