i have a 25/30 up for sale it's a stock rb30 bottom end with a vvt 25 head on it it has the oil mod done and runs a commetic gasket and new water pump and timing belt... asking $2500 neg... throw me a offer i might just say yes.... contact me on 0419653518....
wrong section sorry... can a mod move it please..
Edited by jba05
https://www.sau.com.au/forums/topic/276861-2530-for-sale/
Was anything done to the bottom end before bolting the head on.....
New bearings ????....Rings????
How many k's on the rb30?
What were the bores like??
+1
More info please.
Manifolds? Waterpump? Pulleys? etc
https://www.sau.com.au/forums/topic/276861-2530-for-sale/#findComment-4690210
nothing done to the bottom end...
no new bearings, or rings
done 180.000, to 200,000 kays
and the bores were in top shape not a bit of movement and still see the hone marks on all 6 cylinders.
it has the intake manifold and a stock rb25 exhaust manifold.. had a brand new waterpump on it and a cometic head gasket, and new timing belt as well... no pulleys, got balancer on it as well...
https://www.sau.com.au/forums/topic/276861-2530-for-sale/#findComment-4690994
got no pic atm computer crashed and lost all i had on here but will have some more by the weekend.. and no i'm near plainlands 30 mins before tbar.....
thanks pm pics when you can
https://www.sau.com.au/forums/topic/276861-2530-for-sale/#findComment-4702092
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
