Hey everyone. The time has come for me to sell my 95 R33 GTR Vspec. i have spent alot of time and money on this car but the time has come to buy something a little more practical. Ive owned the car for the last 18 months and has never given me any troubles. It has been serviced regularly with the last service done on the 19/6/2009. Quality parts and oils have always been used. Servicing and pretty much all the recent mechanical work has been carried out by Croydon Racing Developements so quailty of workmanship can be assured.
The car currently shows 35000km's on the speedo but im unsure of original kms as speedo was replaced in japan with A Nismo 320km/h item
Car has rego till May next year
The car currently makes 340kw @ all 4 wheels on 21psi tuned by Jim from Croydon Racing
Engine:
HKS GTRS turbos with heavy duty actuators with braided oil n water lines with speedflow fittings
HKS Balance pipe manifolds with HPC coating
HKS Hard intake pipe kit
HKS intercooler pipping kit
HKS 600x300x100 intercooler
HKS split dump pipes
HKS front pipe
Hi flow cat with custom 3.5" exhaust leading to HKS super Dragger Muffler
Nismo 600cc injectors
Nismo FPR
Bosch 044 intank fuel pump
Apexi Power FC D-jetro
Blitz SBC ID 3 electronic boost controller
Splitfire coil packs
JJR combined washer bottle and oil catch can
GReddy Carbon fibre radiator shroud
Tomei 260* camshafts
OS geiken adjustable cam gears
GREX large oil cooler and oil filter relocation kit
Suspension/ Brakes:
Tein HR coilovers
Whiteline adjustable front and rear Sway bars
Standard front and rear strut braces
JJR b-pillar floor brace
Bendix ultimate pads front and rear
Body:
Genuine Trust/Gracer side skirts
Genuine Trust/Gracer rear pods
Work meister S2R 18x10 +15 rims
Kumho Ecsta tyres 265/35/18 about 75% tread left
Nismo Carbon b-pillar garnish
Nismo Carbon GTR wing end plates
Driveline:
Nismo twin plate clutch
Genuine C's short shift Kit
Interior:
Nismo white 320km/h speedo and centre console gauges
Nismo leather gear knob
Carbon fibre dash and window switch panels
2kg fire extinguisher
Alpine head unit and rear speakers
GReddy boost and water temp gauges in GReddy A-pillar
As you can see, ive used all the top parts and top names throughout the car
Im pretty sure that there are sum things that i have left out.
Overall the car is in excellent condition with only a few scrapes and chips on the front lip.
The body work is very straight and the paint is in excellent condition.
The interior is also in fantastic condition with no rips or tears to seats and the steering wheel is almost like new with no scratches.
If you have any further questions please feel free to pm me
plates will not be sold with the car
Price $36000
https://www.sau.com.au/forums/topic/276953-r33-gtr-vspec/
that thing's seriously awesome!
sorry to get a bit off topic, but where abouts did you get your side skirts and pods from? I gotta get me some of those!
Cheers
thanx mate, got them from japan, there are always sum advertised on import monster
https://www.sau.com.au/forums/topic/276953-r33-gtr-vspec/#findComment-4695793
  • 3 months later...
Hey mate, just wondering if you could tell me where you got the Carbon fibre dash and window switch panels for your GTR?
Cheers
Engine:
HKS front pipe
Nismo FPR
Suspension/ Brakes:
Tein HR coilovers
Body:
Driveline:
Interior:
Price $36000
https://www.sau.com.au/forums/topic/276953-r33-gtr-vspec/#findComment-4881479
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
