the r32s have been legal here for awhile,the r33 gtst's just became legal this year,we have a 15 year importation rule
so the car has to be 15 years or older to import it into canada
the r34 is actually a r32gtr with extensive bodywork done using actual r34 body panels
not something like the beer34 kit,he put alot of time into that to do it properly and it looks great
all the panels/hood etc line up nicely no horrible gaps etc
http://forums.gtrcanada.com/showthread.php?t=28853 this is his build thread,i believe he has one on here too
Edited by pumpkin
We have a 15 year rule too,
But not so much you have to wait 15 years before you can import the car...
Basically any car that is 15 + years old, you have to comply with a few things at the same time you can get away with a few things.
R32 GTR with R34 GTR body kit... Yeah I would not do it... Maybe goes as far as the Bee*R R34 kit and that's it.
But a Great amount of effort would have been put in for sure, on that R32 GTR.
A SAU member did a R33 GTR into a R34 GTR, looks perfect as it tricked me for a bit till I looked carefully at the rear quarter window.
I've done the Vancouver/Banff-Calgary/Edmonton triangle a couple of times now and it's so spectacular scenery there!
Still got rellies in N Burnaby & Calgary
Did you notice that the parking bays are much wider there?
And the owner of the R34 imitation has Bakes' NSW Number Plate.
    • Ironically the GTT was quite reliable in the 7 years of ownership. From memory I've only had to replace a radiator and coilpacks out of inconvenience
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
