Hi guys can someone explain to me how having a BOV vented to the atmosphere increases pollution? No not noise, that isn't the issue, unless it's over the DBA limit of course. The BOV only opens when the throttle is closed and when the throttle is closed the PCV valve draws air from the cam cover venting into the engine where it is combusted and cleaned by the cat.
So if everything is working OK, the only thing that comes out of the BOV is what went through the air filter. Since the air filter cleans out some crap, I would have thought the EPA would be happy with BOV's vented to atmosphere as they clean up the air for us to breath.
Try that next time the pesky pests annoy you.
https://www.sau.com.au/forums/topic/2776-bovs/page/2/#findComment-309431
Yeah but that assumes your engine and BOV are in perfect running order. I would imagine there would be a number of incidences where a sick engine/turbo can spew noxious gases out of the BOV. Also would a venting BOV make the engine run rich? Changing these circumstances would increase noxious emissions?
T.
https://www.sau.com.au/forums/topic/2776-bovs/page/2/#findComment-309632
Hi Tony, a couple of comments following on from your last post.....
"assumes your engine and BOV are in perfect running order"
So the pesky pests should be checking badly running cars, not ones with atmosphere vented BOV's. I followed a car to work this monring that was spewing so bad I had tears in my eyes, had to put the A/C on recirc.
"Also would a venting BOV make the engine run rich"
Yep, but not as much as when the engine is cold. At least the cat will be warmed up when the BOV vents and do something about it. When the engine is rich and cold, so is the cat, so it don't do squat.
Hope that adds to the discussion.
https://www.sau.com.au/forums/topic/2776-bovs/page/2/#findComment-311297
Can you make all BOV's plumbback, or only specially designed ones?
i am not a riceboy but dont have a big adversion to the noise as long as it only comes on when boosting.
But i dont really want a atmo venting one as i couldnt be bothered with the hassle from the cops
yes i will be running large amounts of boost on occasion :D
https://www.sau.com.au/forums/topic/2776-bovs/page/2/#findComment-313070
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
