I have a pair of Recaro's for sale. They came in my R33 but I took them out for compliance and they never made their way back into the car. They are in excellent condition and have had little use, there is no deterioration of the bolster sponge.
I know they fit R32 and R33, but I'm don't know about R34.
Price $1000
Pickup in Melbourne
PM me for contact details
https://www.sau.com.au/forums/topic/277670-recaro-seats-pair-of-for-r32-r33/
ill buy them... where in Melbourne are ya? ill get someone to pick them up!
Please send me your email address via PM (I cannot PM with only 5 posts)
Edited by tteerrrryy
